SHAFT VS BELT VS CHAIN
hawker
#11 Unread post by hawker »
Shaft is best. Change oil every year or two and lube when tires changed is all I've ever had to do. Chain drive was always so messy, slinging grease all the time.
Had a S50 (actually VS800) and loved it. They also make a M50 now which is a little more of a cruiser type and has fuel injection vs the dual carbs on the S50. Price is about the same. Either one is a great choice. I'm sure the others are equally good, just I have no experience so I can't comment on them.
flynrider
#12 Unread post by flynrider »
Back in the bad old days, chains were messy. They required a lot of attention with nasty, sticky chain lube that got flung everywhere once you started moving. With the advent of O-ring chains, life got much easier. The O-ring chain only needs an occasional light coating of lube to keep the links from rusting. The rollers are internally lubricated. On my Nighthawk, I just give the chain a quick spray of some clean silicone lube every month or so and it does fine. Current chain has 14K miles on it and has only needed adjustment twice.
Bikin' John
'93 Honda CB750 Nighthawk
Brent
#13 Unread post by Brent »
Thanks a lot guys. Looks like Shaft is still the way to go,now to decide on the bike..Floorboards or not that is the question.
TechTMW
#14 Unread post by TechTMW »
Footboards can be removed if you don't like them, and they provide comfort in long haul situations ... bad points, they can sometimes reduce cornering clearance. I'd say get the footboards, and if you don't like them you can remove them.
Brent
#15 Unread post by Brent »
But if I am removing them, why not get a cusyom instead?
Lion_Lady
Real Name: Pam
Years Riding: 24
#16 Unread post by Lion_Lady »
Brent wrote:So are you saying you have to get a new tire every year?
Also aside from looks and only from a standpoint of known problems with the S-50,V-star 650, Vulcan 750(which also has I think Hydraulic Valves which eliminates adjusting them) is there a standout among 800cc or less bikes with either shaft or belt? Thanks
Most motorcycle tires will need to be replaced at about 6000 to 8000 miles. Cruisers, with harder rubber in the tires, last into 10,000 miles, and sport bikes with softer, stickier tires need new ones at 3-4000 miles.
Depends on your riding style as well.
P
CentralOzzy
Real Name: AL
Years Riding: 42
#17 Unread post by CentralOzzy »
I have owned bikes with Chains, Shafts & Belts.
BELTS win Hands down....followed by Shaft....& CHAINS CAN GO TO THE GARBAGE.
These days Belts need very little or NO adjustment.
