Brakes,how difficult?
iwannadie
#11 Unread post by iwannadie »
http://www.calsportbike.com/
if you want to make sure on the pads size wise just email them. when i had questions the owner of the company emailed me really quick and answered everything. they ship out fast too.
03 katana 600
txiki
#12 Unread post by txiki »
Thank you, I have sent e mail and he has responded that I need the FD111, so I'm going to order the pads now, thanks again.
Located in Tassachusetts
iwannadie
#13 Unread post by iwannadie »
txiki wrote:Thank you, I have sent e mail and he has responded that I need the FD111, so I'm going to order the pads now, thanks again.
ya same pads as mine, i think pretty much all the newer gsx models use the same rear pads.
dont forget the brake pad grease. you can buy small packets at like any automotive store for a $1 and you just smear some of that on the back of the pad before putting them in.
also you probably will need to bleed the brakes, i know a guy that sells Speed bleeders for cheap if you want to get them. they make bleeding brakes a 5 second job.
http://www.speedbleeder.com/
03 katana 600
txiki
#14 Unread post by txiki »
I have ordered the pads already, the bleeders are nice, do you have them installed? What type the SB7100 or the SB s7100?. Thanks for your help
iwannadie
#15 Unread post by iwannadie »
txiki wrote:I have ordered the pads already, the bleeders are nice, do you have them installed? What type the SB7100 or the SB s7100?. Thanks for your help
yea i got mine installed sb7100, i tried getting them from a local parts shop but they for whatever reason after 3 orderes could Not get the size to fit for me. so after 3 weeks of dealing with them i ordred from this guy i found on http://katriders.com/ and they fit perfect for cheaper than the dealer had ha.
but the bleeders are great, once they are on you loosen it about 1/2 a turn and pump the brake until bubbles stop while filling the fluid a little bit then tighten the bleeder back up and your done. defiantly worth the money i think. i got 4 bleeders plus a 2' foot rubber hose shipped for 29$ and i had them in 3 days.
03 katana 600
txiki
#16 Unread post by txiki »
I'll be ordering them from that guy, do we need 4 bleeders? Thanks again
iwannadie
#17 Unread post by iwannadie »
txiki wrote:I'll be ordering them from that guy, do we need 4 bleeders? Thanks again
im pretty sure 4 for yours too, 1 each front caliper, 2 rear caliper.
you talked to CyberPoet? tell him iwannadie sent ya ;p
03 katana 600
txiki
#18 Unread post by txiki »
You are right, they are 4 bleeders, I have ordered the bleeders and I told cyberpoet that you sent me. Thank you and I will let you know how I do.
txiki
#19 Unread post by txiki »
All done, the bleeders are awesome and the pads were ok, I got stock with one of the pins, but it wasn't difficult at all. Thank you all and specially Iwannadie
