Connecting a gas tank
beerbaron
#1 Unread post by beerbaron »
This sounds rather simple but I'm wondering if I connected my gas tank hoses correctly. I'm pretty sure about the main fuel hose but the other two I'm not sure which one is the depression and which one is the pressure coming from the intake of the engine.
Here is a pic, I just hope I haven't been running on the wrong plug for a 1000 miles.
Thanks
BeerBaron
Gadjet
Real Name: Owen Clark
Years Riding: 19
#2 Unread post by Gadjet »
Part 29 is the vacuum hose that comes off the engine to open the petcock when the bike is running.
Part 27 is a vent line from the tank - this takes excess pressure/overflow fuel and vents it out below the frame.
If you hooked up the vent line and the vacuum line backwards, your bike would not run; ditto with the fuel and vacuum lines
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
beerbaron
#3 Unread post by beerbaron »
Thanks... still searching for that excessive fuel consumption!
BeerBaron :|
Gadjet
Years Riding: 19
#4 Unread post by Gadjet »
excessive fuel consumption is generally the result of a rich condition - are your plugs sooty and black?
if they are, you may want to check the float levels in your carburetors to see if they are set too high, and also check your idle mix screw. If you haven't gotten your carbs sync'd, you may want to do that.
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
