The Last Little Thing
Aquaduct
#1 Unread post by Aquaduct »
Bought a 1999 Triumph Trophy 1200 last spring that wasn't running real good and I've put close to 7000 miles on it and sorted out a bunch of problems. Although it's never left me stranded, there have been a number of serious PITAs. The pickup coil has been replaced. The fuel system revamped from some previous erroneous repairs and the evaporative system has been scraped (the open-ended evap hoses are still in place since the gas cap doesn't vent). The throttle cable has been rerouted so the throttles close. The carbs have been balanced. A can of Seafoam has been run through it. The petcock has been replaced and, finally, it's got new plugs.
Runs pretty good now except it'll still give me some trouble after running for about 20-25 miles. One thing it'll start doing is sputtering and bucking around 2000 rpm, typically accelerating away from a stop, etc. It's almost like the torque curve has fallen off at low rpms and when you accelerate, it's lugging. Sometimes, if I don't really give it much gas, it'll go up through that range without a hitch. But any normal pull and it bucks and can stall. Sometimes it'll just stall while waiting for a light.
Another thing it'll do is if I'm on the freeway at 70+ mph for 20 miles or so, it'll start to drop out and can even stall when I finally get off the freeway. The petcock was causing this real bad and it's better now, but not gone entirely. If I stay on secondary roads, I don't have problems at speed.
Now both of these problems seem to show up and then, quite often disappear, making diagnosis tough.
Other things I've noticed is the idle doesn't seem terribly stable. Not bad, but you can kind of feel a miss every now and again. Also, the choke makes it run while cold, but it seems to exacerbate the instability.
A couple of my thoughts would be that the Autolite plugs I put in are crap and should be changed again. Or maybe the valves need adjustment (they probably could use it anyway, but it's a pain on a 16-valve faringed(sp?) bike like this one). Or maybe I just need to pull the carbs entirely and rebuild them.
Any good ideas from the collective experience? I'm so close I can taste it.
flynrider
#2 Unread post by flynrider »
I had a problem similiar to this that turned out to be a sticky carb float. What caught my attention was that you said it happened on the freeway, but not on secondary roads. And also that it could happen while standing still at a light. Mine was exactly the same. A float would stick in the "up" position, starving one of the carbs and causing the power to drop off at speed, and idle badly. It wouldn't happen on secondary roads because the stops, starts, curves and potholes would jar the carb enough to keep the floats from sticking. I confirmed the problem by taking the bike onto the freeway. When it finally started to bog down, I pulled a long box end wrench out of my back pocket and tapped on the carbs. Power came back within a few seconds. Give it a try.
Bikin' John
'93 Honda CB750 Nighthawk
#3 Unread post by BuzZz »
Could well be that the valves need setting. And weak plugs can mess with idle and low RPM running. You may see some benefit from fine-tuning of the idle/air mixture screw as well.
led_zeppelin
#4 Unread post by led_zeppelin »
too much gas for the amount of air. running rich...
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
Re: The Last Little Thing
#5 Unread post by Gummiente »
Aquaduct wrote:Although it's never left me stranded, there have been a number of serious PITAs.
I could fill pages with the issues I experienced with my '01 Tiger 955i and '95 Thunderbird. I don't have any experience with the Trophy, though... have you joined any Triumph forums yet? I found them to be of invaluable assistance, way more than my dealer ever was.
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
Aquaduct
#6 Unread post by Aquaduct »
Gummiente wrote:I could fill pages with the issues I experienced with my '01 Tiger 955i and '95 Thunderbird. I don't have any experience with the Trophy, though... have you joined any Triumph forums yet? I found them to be of invaluable assistance, way more than my dealer ever was.
Thanks guys, good thoughts. Gummiente, no, I haven't found any Triumph forums and I'm dang near the only one here. Any specific suggestions?
