Electrics Anyone?
Henriettaah
#11 Unread post by Henriettaah »
- Maybe it meant the whole headlamp fixture rather than just the bulb.
9000white
#12 Unread post by 9000white »
i dont know if it is the whole thing.the headlight on my 82 v45 sabre went out and the price was $53.00.i said no way and used a car light.had to file a small groove in the bucket for a tab on car light it cost $5.50.
dr bob
niterider
light
#13 Unread post by niterider »
Remove head lite find common ground, ground it, and apply 12 volt to the other two posts endividually. If the lite works both times it is probably good.
9000white
#14 Unread post by 9000white »
get the test light so next time something quits you can check it.it will do more than check headlight wires.
dr bob
