I guest the shim on the top of the buckets would be just a cover removal, turn crank bolt, measure, pull shims, and replace, right?
I'm just asking for future reference, not to be a pain
Vulcanman500 just has locknut and screw adjusters.
Yeah, the 800 has an over-bucket type, Ron. They're really easy to adjust - the tappet is spring-loaded and slides out of the way to replace the shim, then you just release the tappet and it slides right back in place. The hardest part is getting access, especially with the rear cylinder. You pretty much have to disassemble the top half of the bike to get the valve covers off.ronboskz650sr wrote:Poppygene, do you know if it's shim over or under the bucket? My 650 has it under the buckets, and you have to remove (or carefully set aside) the cams to get them out.
Hey, it's not a problem - the only thing we'll miss is being able to see that big grin on your face when it all works right!glarkin wrote:Thanks, I am sorry to send all of the messages, but your response sounds like it could be it. Anything special I need to know when I take out the jet? Thanks again. Can I do that without removing the carburator?
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
