**Winterization**
**Winterization**
#1 Unread post by BuzZz »
For any and all interested parties, here is a very good article written by The Commander.... aka Mike, that details most all concerns you may have. Give it a read, it's worth it.
http://totalmotorcycle.com/maintenance/ ... torage.htm
rapidblue
#2 Unread post by rapidblue »
good read I do have a questions though, since my bike is an old piece of sh@# and I am running premix (about 32:1) can I still use stabil and leave the gas/oil in the tank or do I have to do something different because of the premix?
Thanks
80 honda CB750F Super Sport
#3 Unread post by BuzZz »
You can just treat your pre-mix like straight gas. Stabilize away.....
rapidblue
#4 Unread post by rapidblue »
right on
thanks
oldnslo
Real Name: Lamont Cranston
Years Riding: 20
#5 Unread post by oldnslo »
Winterize? My only acknowledgement of winter is to wear warmer riding clothes. Never, or nearly never snows or freezes in the vacation paradise where I live. :)
John
"83 XJ900RK
flynrider
#6 Unread post by flynrider »
I can relate. Here in PHX winter is the time of year you can go out riding without fear of heat stroke. It's some of the best riding weather we get all year.
Bikin' John
'93 Honda CB750 Nighthawk
#7 Unread post by BuzZz »
Oh, "pee"-off, the both of ya's. :wink:
Your just jealous that you can't store your bike away for months while you sit there depressed and freezing your nuts off..... no wait, that's not right............
craap
oldnslo
Years Riding: 20
#8 Unread post by oldnslo »
A generous supply of strong alcoholic beverages helps you to at least think you aren't depressed, even if you are.
John
"83 XJ900RK
Shorts
#9 Unread post by Shorts »
Remove the spark plugs and pour a tablespoon (5 cc) of clean engine oil or spray fogging oil into each cylinder. Be sure to switch off the fuel before you crank the engine or else you may refill the drained carbs! Also, ground the ignition leads to prevent sparks igniting any fuel residue. Turn the engine over several revolutions to spread the oil around and then reinstall the plugs. Refitting the plugs before cranking the engine could result in a hydraulic lock if too much oil was used in the cylinder.
Ok, dumb question time - how do I crank the engine over without running it? I'm assuming this is manually cranking it, but how? Is it just a matter of spinning the rear tire? Or am I completely off?
#10 Unread post by Sev »
Hit the starter with no gas in the carbs?
