Need to find new relay unit HELP HELP
Coil
#1 Unread post by Coil »
Hello Yall,
Got me a 85 Virago 700. Was running great. Had both hands operated on and could not ride for about 2 months. But I aint stupid (unless you ask my wife) and started it about 2 times a week. Then when I was ready to ride, the damn thing will not turn over.
Turn key to on position, headlights come on as normal. Press the start button and all that happens is the headlight turns off. Check at the starter for juice = nothin. Follow back to the starter relay. Arch the relay with a screwdriver and she fired up and purred like a fuzzy kitty at the titty bar after a huge tip. So I traced all the wiring (all the netural safety, side stand safety, clutch safety, "O Ring" in the seat safety, no broad on the back safety) and traced the problem to a relay under the seat. But I will be damned if I can locate one other than the dealer (for a small fee of $135.00.......up yours!)
The relay controls the turnsignals, safety start, brake lights and all the jazz. It has a part number on the front of 41R-71.
What the hell caused the damn thing to go bad and ANYBODY KNOW WHERE I CAN GET ONE WITHOUT HAVING TO CUT OFF MY LEG, ARM, OR NUT?????!!!!!!
Thanks yall,
Coil
niterider
may sound silly
#2 Unread post by niterider »
This may sound silly, but have you checked the starter lock out switch on the right hand controls?
Coil
#3 Unread post by Coil »
uuuuhhhhhh well like yea.
Yes I have. Like I said I traced it down to this relay unit.
Mottoxfox
#4 Unread post by Mottoxfox »
I'll help you get it going PM me
1978 Yamaha XS1100E
1982 Yamaha Seca Turbo
1982 Yamaha 750 Maxim
1983 Yamaha XVZ1200TK Venture
