i have read about people using por-15 to clean their gas tanks in many places, and all the good things they say. my problem is i dont really have the time or place to do such a hard core cleaning and sealing.
a friend of mine suggested i use naval gel to de-rust the inside of my tank, i also have rust spots on the outside of my tank..
is there any reason using the naval gel to de-rust the inside of my tank is a bad idea? i know it wont seal the gas tank, so i could end up with rust later, but im not worrying too much about that now, maybe ill get a seperate sealer kit when i have the space to put my tank and work with noxious fumes.
i figured i would rattle around some nuts inside to loosen the really loose stuff, clean out the tank thuroughly, then throw in the naval gel, and on the outside sand off the flaky stuff and paint on a little bit of naval gel as needed.
sound ok?
and once i fix up the rust spots on my tank what should i use to keep it rust free outside? i know there is some kind of auto base paint something for that.
thanks
edit: i went to the auto store here and 1) they were out of naval gel, and 2) the guy said you need to rub naval gel and stuff, so it would not be good to use inside a tank.. i guess that means im gonna end up getting something like the por-15 and figure out some place to deal with all of it.. working on a bike in college dorms SUCKS!
