Front disc dragging.
My front brake (single disk hydraulic) was a bit mushy, so I bled it. It was still squishy, so I pulled the caliper and noticed that the piston was having a lot of trouble moving. I removed the caliper, disassembled everything, cleaned it, put everything back together, and flushed and bled the system. The brakes are much better, but I determined that I still need a new piston and seals as well as pads (probably upgrade to stainless lines while I'm at it).
The problem is that my front brakes drag now. Before I started, I could kick the front wheel and get a couple of rotations. Now, although it is still easy to move the wheel, it does not spin freely. There is no effect when riding and the rotor does not heat up.
I think this is OK, and the new piston and seals will remedy the problem, but I wanted to run it by the folks here to see what you all thought.
1982 Yamaha XS400J Maxim - Black
- mydlyfkryzis
- Legendary 500
- Years Riding: 42
The pad is supposed to drag lightly. That keeps wiping it clean and if you are in the rain, keeps wiping the water off.
If the caliper and pad are not overheating, then it sounds right. There is a check valve in the master cyclinder that keeps a little pressure on it for this reason.
Richard - Fully Dressed
Naked 1976 Honda CB360T
Take back apart the front caliper. The square Oring needs to come out to be cleaned. Scrape the recess groove for the oring until clean. Then I use a single edge razor blade and gently scrape all 4 sides of the oring. Lots of times old crusty brake fluid gets behind the oring pushing it out against the piston causing it to seize up.
1978 Yamaha XS1100E
1982 Yamaha Seca Turbo
1982 Yamaha 750 Maxim
1983 Yamaha XVZ1200TK Venture
- Regular
Thanks
Thanks for the replies. The piston has some marks on it and the square o-ring is really chewed up which is why I say that I still need to replace a few parts. I just have to set aside time for it.
- Veteran
how do you remove the piston from the caliper as mine are sticking a lot as well?
1973 Honda Cl 350 (Sold)
1982 Honda 650 Nighthawk
1978 Kawasaki KZ 400 (Sold)
1983 Kawasaki GPZ 550
But someone will say, "You have faith; I have deeds."
Show me your faith without deeds, and I will show you my faith by what I do.
James 2:18
James 2:18
you can get the caliper pistons out by removing the pads and pumping the brake lever.it is best to put a piece of wood between the pistons so they dont come all the way out.sometimes one of them wont move and the other comes all the way out leaving no way to move stuck piston.when they are almost all the way out put a rag around the piston and pull it out with a pair of pliers.if you have a air compressor you can blow them out.you can hook a grease gun to the bleeder screw and push them out with grease.this makes a big mess.hardware stores carry an internal pipe wrench that you can split the caliper and pull them out with the wrench if you have hollow pistons.dont scar the outside of them pistons with pliers or you will get to buy a nice shiny set of new ones.
dr bob
- Veteran
alright now that I have the pistons out what am I focusing on to clean?
James 2:18
James 2:18
