sv-wolf wrote:I've just had a look back over the last hundred odd threads in this forum. Would you believe that a 'Nerds Corner' like this has generated more hits than any other except one (and that, of course, has 'women' in the title.)
Ride safely everyone (with or without the aid of centrifugal force!)
And centipedes and telescopesNibblet99 wrote:
also centrifugal force doesn't exist, there's only a centripetal force acting in gyroscopes
Sorry, Sev. It wasn't. You consistently got the two different uses of the idea mixed up. As below.Sevulturus wrote:Exactly what I was trying to say, thankyou.
'Centrifugal force' can only 'push back' against centripetal force when considering the forces within a revolving system, not when considering the forces on it. You do not need something to 'push back' against centripetal force to prevent the bike going over. The couple produced by the lean (the bike's weight and the vertical reactive force at the wheel) does that for you.Sevulturus wrote:Every action has an equal and opposite reaction. So basically Centrifical force is the force that pushes back against Centripital force. Otherwise the bike or car would go over the otherway.
It doesn't actually exist of itself, but it is used to explain why things move to the outside of a turn.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
