At Long Last... And Pics.
ronboskz650sr
#21 Unread post by ronboskz650sr »
I used an antifreeze bottle for the undertray on mine when i eliminated the rear fender. I laid a piece of it on the frame and heated it with a heat gun until gravity pulled it down into shape over the rails. Trim it to match the frame shape, or whatever. I used the original fender mounting bolt locations to attach it under my fender eliminator and wiring. Put the seat back on and voila!
Ride safe...God bless!
-Ron
cb360
#22 Unread post by cb360 »
Nice job Henriettaah!
1974 Honda CB360
1985 Honda Magna VF700c
Ninja Geoff
Real Name: Geoff
#23 Unread post by Ninja Geoff »
Henriettaah wrote:
GeoffXR200R wrote:Is it gonna get jacked up once you get really good at tossing Elsie around
Do you mean tweak up the torque/bhp? :blink: Don't know when I'll be ready for that :whistling:
$10 says (what is that? like 5 Euros?) that by the end of next riding season you'll be able to (and want to) handle more power. first you crawl, then you walk, then you run. you're walking now, it's just up to you when you decide to run.
Henriettaah
#24 Unread post by Henriettaah »
Any of these 'aluminium sheets' suitable?????????
http://search.ebay.co.uk/aluminium-shee ... sacatZQ2d1
Ninja Geoff
Real Name: Geoff
#25 Unread post by Ninja Geoff »
Henriettaah wrote:Any of these 'aluminium sheets' suitable?????????
i vote for http://cgi.ebay.co.uk/NEW-5mm-ALUMINIUM ... dZViewItem
easiest to shape. also, don't forget about http://cgi.ebay.co.uk/AVIATION-TIN-SNIP ... dZViewItem
Henriettaah
#26 Unread post by Henriettaah »
I was going to ask about the thickness in another thread - but here we are :)
5mm??! Do you know, I was going to ask if 1mm would be sufficient :oops: Does it have to be as thick a grade as 5mm??
Ninja Geoff
Real Name: Geoff
#27 Unread post by Ninja Geoff »
Henriettaah wrote:I was going to ask about the thickness in another thread - but here we are :)
1 mm is REALLY thin. Go to your local hardware store that carries aluminum and check some out. The 1 mm stuff just doesn't seem too durable to me, that's all. Though i work with computers, not metal so i'm sure someone else can correct me.
ooo, this may look cool
http://cgi.ebay.co.uk/5-BAR-2mm-ALUMINI ... dZViewItem
Henriettaah
#28 Unread post by Henriettaah »
Hmm, yes it needs to be durable - but I think (for me) to work with it'll need to be a little flexible too. I'll have to do some research and consulting tomorrow i think :wink:
I can imagine the effect I'd like is to be a totally smooth surface with no fixtures, nothing, on the underside.
Ninja Geoff
Real Name: Geoff
#29 Unread post by Ninja Geoff »
Henriettaah wrote:Hmm, yes it needs to be durable - but I think (for me) to work with it'll need to be a little flexible too. I'll have to do some research and consulting tomorrow i think :wink:
whatever you end up doing, can't wait to see the results.
Henriettaah
#30 Unread post by Henriettaah »
GeoffXR200R wrote:ooo, this may look cool -2mm-ALUMINIUM-SHEET-TREADPLATE-
Heh I saw that too!
