Piston/cylinder clearance
RideorDie976
#1 Unread post by RideorDie976 »
I'm putting a new piston in my yz80 and i cant find anywhere what the piston/cylinder clearance is supposed to be, do you what its supposed to be or where i can find out?
Thanks,
David
mydlyfkryzis
Years Riding: 42
#2 Unread post by mydlyfkryzis »
You really should get a manual. That's a pretty ambitious project to take on without having clearances and torque values.
You need to check ring gap as well as piston clearnance. Heasd Bolt torque values, Valve clearances if 4 cycle.
Richard - Fully Dressed
Naked 1976 Honda CB360T
Mottoxfox
#3 Unread post by Mottoxfox »
I would go about .0015 on the bore but check else where for the Factory spec.
1978 Yamaha XS1100E
1982 Yamaha Seca Turbo
1982 Yamaha 750 Maxim
1983 Yamaha XVZ1200TK Venture
RideorDie976
#4 Unread post by RideorDie976 »
Thanks for the info. I am supposed to be getting a manual from a friend but i havent got it so i'll just wait till i get it rather than take any chances.
David
[color=blue]Ride hard, or die tryin,
and if you cant, then
wish you could [/color]
