NFL Helmet for Motorcycle use.
Vit0r
#1 Unread post by Vit0r »
How would a football helmet hold up for motorcycle use? They're proven on the football field but how would they hold up against asphalt?
Ninja Geoff
Real Name: Geoff
#2 Unread post by Ninja Geoff »
Is it DOT approved?
Vit0r
#3 Unread post by Vit0r »
It's NFL licensed. NFL...DOT...close enough.
jmillheiser
#4 Unread post by jmillheiser »
not well at all. football helmets are designed to take a completely different type of impact than a motorcycle helmet.
what helps a motorcycle helmet save your "O Ring" is the lining (not the soft cushy liner that touches your noggin but the harder foam liner that is between the soft liner and the shell). This lining is designed to compress under impact and reduce the rate of deceleration of your brain, and its only designed to do this ONCE.
Vit0r
#5 Unread post by Vit0r »
So wouldn't a football helmet be better since they can take impact more than once?
Ninja Geoff
Real Name: Geoff
#6 Unread post by Ninja Geoff »
Vit0r wrote:So wouldn't a football helmet be better since they can take impact more than once?
No. There's a differance between the force of hitting the ground at 40 mph and getting slammed to the ground at much slower speeds.
jmillheiser
#7 Unread post by jmillheiser »
If its a linebacker hitting you then yes.
#8 Unread post by Sev »
That seems a lot like asking if a standard bulletproof vest will stop a knife.
The answer is no. They aren't designed to do that.
Mustang
#9 Unread post by Mustang »
I can see how an NFL player would seem daunting, but to compare a hit from one of them to hitting the asphalt at 40 - 70 miles per hour seems a little silly.
Could you imagine if the NFL had to replace their helmets everytime they were dropped or as is usually the case, thrown!
[b]Other Daily Reads[/b]
[url=http://bikerdiaries.blogspot.com/]Biker Diaries[/url]
[url=http://www.clutchandchrome.com]Clutch and Chrome[/url]
[url=http://totalmotorcycle.com/BBS/index.php]The motorcycle Forum[/url]
c-los
#10 Unread post by c-los »
in every game AT LEAST one football player has his helmet come off after a hit...imagine that happening at 60 mph?
