bhp
vega44
bhp
#1 Unread post by vega44 »
what does bhp mean???
#2 Unread post by Sev »
I always thought it was brake horsepower. Or the HP that is generated at the wheel, as opposed to at the crank where you haven't lost any in the drivechain.
DivideOverflow
#3 Unread post by DivideOverflow »
bhp is brake horsepower... It refers to the brake dynamometer, the device for measuring the true power of the engine. Stating power in 'bhp' gives some indication that this is a true reading, rather than a calculated or predicted one. However, it does not tell where the power reading was taken — at the flywheel, transmission or drive wheels.
Most of the time, manufacurers will test at the crank and call it bhp. If you see it from a manufacturer, it is safe to assume that it is measured from the crank, and does not include drivetrain losses. I haven't known any manufacturers to actually test from the wheels.
shane-o
Years Riding: 17
My Motorcycle: VTR1000
#4 Unread post by shane-o »
DivideOverflow wrote:bhp is brake horsepower... It refers to the brake dynamometer, the device for measuring the true power of the engine. Stating power in 'bhp' gives some indication that this is a true reading, rather than a calculated or predicted one. However, it does not tell where the power reading was taken — at the flywheel, transmission or drive wheels.
your prolly right but im sure ive seen manufactures getting all excited by dyno results, or maybe not :wink:
DivideOverflow
#5 Unread post by DivideOverflow »
they usually dyno the engine by itself. it makes their numbers look better.
