quick winterization question
- nyrblue35
- Legendary 300
its winter here and damn cold. 30 degrees. im going to be going away for a week and will be storing my bike in a friends garage. im in the process of moving so it will be staying in my friends place for about a month until my new landlord clears a spot in his own garage for it. my question is should i run the bike with the petcock off to drain the carbs and stabilize the tank? or should i not bother and just keep the tender on it and just cover. thanks for any advice
See my bike and accessories at
www.CruiserCustomizing.com/nyrblue35
- Sev
I think less then 4 months to be stored and it's not worth worrying about. More then that, and you might as well, because hey, it cannot hurt.
- scan
- Legendary 1000
- Years Riding: 8
- My Motorcycle: 2003 Kawasaki ZRX1200R
I store my bike as little as possible throughout the non-riding season. Since that can backfire (like it snows several inches and it stays very cold for a few weeks) I put a dash of Stabil in each time I fill the tank in the winter. See, this way if it has to sit for a month the fuel will be protected. I've heard using lot of Stablil will help foul your plugs, but I think it would take running A LOT of it before this would cause a problem. I've done this the past two years without a problem. If I know there is a big drop in temp or a storm coming I'll pull the battery and stick it on the charger. Pre-cold season I check to make sure my anti-freeze is good for keeping my block from freezing.
* 2003 Kawasaki ZRX1200R *
- nyrblue35
- Legendary 300
with that beind said is it ok to leave the battery tender on it while the battery is still in the bike? i mean i know the tender will do just fine to fully charge the battery while still in the bike and what not but what about say......... for a few weeks to a month? does the batery really need to be removed if the bike will be garaged?scanevalexec wrote: If I know there is a big drop in temp or a storm coming I'll pull the battery and stick it on the charger. Pre-cold season I check to make sure my anti-freeze is good for keeping my block from freezing.
- scan
- Legendary 1000
- Years Riding: 8
I will leave this for someone else to answer specifically. Year before last I had a bike with wires running outside the gas tank that ran to the battery. It had a little connector that matched that one on my tender. That is how I trickle charged that year. On my current bike it is easy to pull the battery, so I just do that, but I am not sure of the implications of charging the battery on the bike still wired up. It didn't hurt my previous bike though. I guess you could pull the possitive and negative wire and leave the battery on the bike charging.
- ZooTech
- Legendary 3000
- Years Riding: 18
If you're only talking about a month just let it be. My bike sat in the garage this winter for almost three months, with temps getting close to zero on a number of occasions in the evening, and when I went out there to see if it would crank it fired right up without hesitation. I did end up pulling the battery after running around the block a few times, but just ended up putting it back in a week later when we had a warm weekend.
