Thing is I couldn't find in my Haynes specs what the desired PSI is for the LC. Its perfectly possible I've gotten mixed up in my calaculation attempts
Thing is, disregarding the above and sticking with PSI's, I'm not convinced that the compression gauge I used is functioning correctly.
Each crank, the gauge would bump up to around 60PSI. Then, as soon as the kick start pressure passed, the meter would drop back down to 0. It wouldn't stick there so it could get bumped up a little bit more at the next kick. From what I understand, for this to happen, the bike would have to be pretty much a dead-knackered-heap with a seriously major compression leak/problem somewhere, and there's no way it would even start no matter run pretty well at speed!
Any thoughts?
I haven't taken the bike out since the head nut tightening, I need to run it around and around so the engine gets nice and hot to see what happens - while staying close to home in case we have cut out again.
