oil changes
KeithB
oil changes
#1 Unread post by KeithB »
my 2005 Honda Shodow Spirit owners manual says to change oil first time at 600 miles, that makes sense
then is says every 8000 miles, that is nuts
i change my car and truck at 3500
what milage do you guys change your bikes oil and filter?
Thanks
KeithB
flynrider
#2 Unread post by flynrider »
I do the oil and filter every 3,000-3,500 mi., or 4 months. Whichever comes first.
Bikin' John
'93 Honda CB750 Nighthawk
mustangski
#3 Unread post by mustangski »
I agree with the every 3000 miles idea. I only follow mileage, I don't follow the 3-4 month rule. I don't believe oil gets old just sitting there.
2001 Victory V92C
2002 Honda Shadow 600 (Finally gettin my wife ridin!)
2000 Harley Davidson Sportster (Sold)
1984 Honda Magna V45 (Sold)
Semper Fidelis
flynrider
#4 Unread post by flynrider »
The reason for my 4 month rule is that oil builds up acids (mostly sulphuric) as byproducts of combustion. You don't want to leave that stuff sitting in the crankcase forever. 4 months is kind of arbitrary. It's the interval that is recommended for my air-cooled airplane engine, so I've just applied it to the bike. Since the bike is built to tighter tolerances, it could probably go longer.
Bikin' John
KeithB
#5 Unread post by KeithB »
Makes sense John, maybe good idea to change the oil before the bike is put up for the winter then even if less than 3000 miles.
KeithB
Ladymx
#6 Unread post by Ladymx »
first oil change is usually with in the 600 miles and then 3000miles is good. The first 600 miles is to get ride of any metal filings that have come lose from the initial riding.
niterider
#7 Unread post by niterider »
If they are using a synthetic oil, it will go a considerable longer amount of miles. Rigs (18 wheelers) run 12,000 to 15,000 miles on a regular oil, and 50,000 or so on synthetic oils with filter changes before the oil change. However, they do hold up to 10 gallons in the pan. I do my cages at 3,000 and my bikes at 1,500 miles.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
