Harley
Noah1504
Harley
#1 Unread post by Noah1504 »
Hey I have a late 84 Sportster I rebuilt the motor because I floated a valve. well I ride it now and I can make it about half way around the block and it dies just shuts dead off. it idles fine and for a long time but as soon as I start to ride it shuts off I can start it right back up im running out Ideas any help?
Noah
vector18
#2 Unread post by vector18 »
Sell it...........
For pics of my bike goto http://rswarrior.com/Gallery/vector18.aspx
#3 Unread post by BuzZz »
Maybe a fuel delivery problem. When you use all the fuel in the carb, it can't fill it up fast enough? Would still idle with a small trickle of incomeing fuel.....
Is there a fuel filter on it?
jmillheiser
#4 Unread post by jmillheiser »
check your needle & seat. carb could be running dry or it could be getting too much gas and flooding, shot needle & seat can cause either of these.
edit: oops forgot HDs only have 1 carb, im so used to multiple carbs from my bike and my VW.
hdtech
#5 Unread post by hdtech »
not too sure about the older sportys, but I have seen this same problem in the newer ones. Check the ignition module, sometimes vibrations and heat could cause them to quit, espectially if it is 18 y/o.
