Honda CM200T Twinstar Oil Screen
iav8
#1 Unread post by iav8 »
The Honda CM200T Twinstar owner manual says to "clean the engine oil screen" but does not show where this screen is. Could someone please tell me where it is and how I should clean it?
BTW why didn't they fit an oil filter?
2009 Suzuki DL650A V-Strom (aka Wee-Strom)
1985 Honda VT500C Shadow
1982 Honda CM200T Twinstar
TechTMW
#2 Unread post by TechTMW »
The Oil Screen is usually inside the engine case above the drain plug.
If I'm not mistaken, there should be a little panel above the drain plug on the side of the case to pull it out.
Dunno why they didn't use a filter ... guess they just felt it wasn't needed ... :|
iav8
#3 Unread post by iav8 »
Thanks for the info... I took a quick look but could not see an obvious panel. I'll take a closer look when we bring the bike out of storage. Cheers.
iav8
#4 Unread post by iav8 »
To wrap up this thread: I got an aftermarket service manual and now know exactly where and how to clean the oil screen. In case any other Honda CM200T (or similar model) owners find this thread, here is the short story: it is under the right-hand crancase cover; it is recommended that the oil pump be removed in order to clean the oil screen.
TechTMW
#5 Unread post by TechTMW »
Thanks for the update and the Information!
