Tires on concrete?
Tires on concrete?
Will leaving my bike in the garage for the winter hurt the tires? Will constant contact against the concrete, or the constant lean of the bike on the kickstand hurt the tires (flatspots) or the forks at all?
- ZooTech
- Years Riding: 18
I've heard arguments either way. But the folks that say it will do harm offer up pretty easy solutions such as parking the tires on a sheet of plywood, moving the bike a couple feet every few weeks, or storing the bike on a stand. First decide whether to believe the concern, then choose a solution if applicable.
- sapaul
- Years Riding: 90
Of more concern if you are leaning the bike on the sidestand for an extended period, is too make sure that you get the bike upright for an hour or two before you start it. The BMW 650's have blown oil pumps because of this.
I think that the real concern here are the tires, They may get flat spots if they are under inflated. I don't belive that the concrete will hurt anything.
You might want to set the bike on a block that hold both tires off the floor.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
one seater
horn relocation
I have never had a problem with flatspots, and I have parked several bikes for extended periods over the years. One thing I make sure to do is roll the bike once a month, so it's resting on a different spot. I can't say whether or not flatspots will occur if you don't roll it once in a while. Also I believe it is better on things like wheel bearings etc. to not have the bike weight on the same spot all the time.
Just my 2cents worth.
DocXander
SCRC 443 Victoria
1995 Suzuki VS800 Intruder
1982 Yamaha Maxim 400
Life is a Highway... wanna go for a ride?
SCRC 443 Victoria
- scan
- Legendary 1000
- Years Riding: 8
- My Motorcycle: 2003 Kawasaki ZRX1200R
I think unless you leave the bike sitting for more than a month without moving it, you shouldn't need to take extra precautions. Roll it forward a few inches, or put a board under the wheels, or jack up the wheels so they are not resting on the concrete. I think it applies to ALL tires, but I think it is a long term storage problem. You see? Leaving it on the concrete in one spot MAY (but may not) cause a flat spots where it has been left sitting unmoved. I believe myself that flat spots will not happen after even a couple months sitting. I've left my bike sit without movement for a month and a half, and no flat spot. My tires are not cheap, so I would not take a chance if I thought it mattered.
* 2003 Kawasaki ZRX1200R *
- Veteran
