Chain Tension
Caper#5
Chain Tension
#1 Unread post by Caper#5 »
How much tension, or how tight should your drive chain be?
2005 Suzuki 650 Bandit S
Everyday is a good day to ride!
Skier
Re: Chain Tension
#2 Unread post by Skier »
Caper#5 wrote:How much tension, or how tight should your drive chain be?
I believe your owner's manual specifies this. If not, pick up a repair manual for your bike and it will say in there.
Caper#5
#3 Unread post by Caper#5 »
I called the dealer today and he said my manual will be in the mail tomorrow, so hopefully I should know that by the end of the week.
Thanks
jpaul
#4 Unread post by jpaul »
A good rule of thumb is to have 1 - 2 inches of slack in the middle of the chain.
Pongo
#5 Unread post by Pongo »
Rule of thumb:
You need to compress the rear suspension to the point where the wheel spindle, swing-arm bearing bolt and the front chain-sprocket centerline are all in line. That is the point of maximum chain tension. To do that get a couple of heavy guys to sit on the bike or use a ratchet tie down.
The free up and down movement at the middle of the chain's bottom run should be about half an inch with the suspension compressed.
Caper#5
#6 Unread post by Caper#5 »
Thanks Pongo and jpaul for the help.
