Never heard of a bike getting rusty just from the rain, unless some paint has been scraped off some metal on the body.
Dunno, but I thought bikes were built to withstand normal weather conditions just like cars.
2002 Buell Blast 500 /¦\
cool then, it's just that my friends bike got corroded on some parts since his bike wasn't garaged parked therefore rain got on it etc. although maybe him barely using it wasa factor as well.
i hope he uses it again soon since his bike is an '05 gixxer600. it'd be a travesty if it doesn't get used.
I think that him barely using it was a bigger factor than the rain. Just leaving a bike sitting out in the open unused I imagine can produce lotsa rust.
Metal will only rust if exposed to water for an extended period of time. If you're ana you can wipe it dry to prevent water spots on the paint, otherwise I'd just leave it myself. Once salt or other stuff gets added to the mix your bike is done for, but by the time air dries in the garage nothing could have possibly happened.
However if you have scratches in the paint, or leave it exposed to water for an extended period you will develop rust patches.
Depending on how hard it's raining when I get home, I've been known to haul out a bucket of soap and water and give the bike a once over. It gets rinsed in fresh clean rain water that way, and then you just roll it into the garage, throw a half dozen coats of wax on it, and it SHINES like nothing you've ever seen.
Sevulturus wrote:Once salt or other stuff gets added to the mix your bike is done for, but by the time air dries in the garage nothing could have possibly happened.
i don't think i encountered salts in the road... so what qualifies for "other stuff" you mentioned?
A variety of minerals used to melt snow and ice deposits on roads. Nothing you need to worry about.
