Your bike isn't made out of cheese, it can stand up to a suprising amount of abuse if you really think about it. It's mostly metal, and despite the fact that it has a lot of moving parts it will hold you in good faith so long as you keep the chain lubed and adjusted oil in the oil holder and gas in the tank.VermilionX wrote:thanks sev!Sevulturus wrote: A variety of minerals used to melt snow and ice deposits on roads. Nothing you need to worry about.
There are obviously some things that can hurt it, but so far everything you're concerned about is at best trivial. My best advice is to just ride the darn thing, and not stress about it so much.
Dumping it will hurt the bike, getting it wet will not. Taking a sledge hammer to it will, letting it sit for a couple of days won't.
Relax, you're supposed to have fun on it, not worry about every little event. My bikes sat outside through rainstorms where the wind was gusting above 90km/h (it shut down the cranes at work) water was literally blowing horizontall with lightning flashing so hard that it might as well have been day.
It's sat outside during duststorms that made me want to cry.
I habitually keep many many many coats of wax on it. For a while I was putting 5 on it every weekend, so this goes a long way towards protecting the paint.
It's been ridden wehn after you factor in windchill it was 10 below freezing celcius, and for the last.. 4 months it's sat in my garage, which has been below freezing every day, all the way down to minus 40 C (same as mins 40F). When the time comes, I'll haul it back out stick the battery back in, prime the carbs and let her rip.
Don't worry so much mate.
