oiled/lubed parts and rain?
VermilionX
Super Legendary 5000
#1 Unread post by VermilionX »
i forgot to ask this before...
i rode in the rain yesterday so how about those oil in the chain and my steering damper?
i looked and felt my bike's damper and they were dry. i know it's supposed to have oil in it but now it doesn't.
will this still be ok even if the rain has washed away the oil?
#2 Unread post by Sev »
Oil resists water, and in this case the oil is a lot stickier then the water, so your chain will be fine. Make sure it's free of dirt and dust etc.
As for your damper... what's a damper?
Shiv
#3 Unread post by Shiv »
Steering dampner.
It helps with steering, that's all I know.
How it helps, I don't know. I think it helps keep the front straight and lessens the risk of tankslappers.
Have fun on the open /¦\
www.totalmotorcycle.com
I know, I was surprised too.
VermilionX
#4 Unread post by VermilionX »
AFAIK... it prevents tankslappers.
#5 Unread post by Sev »
Do'h I should have known that, just never heard it refered to as just a damper before. Always heard steering damper. Anyways, that'll be fine, really I think you worry to much :D
jmillheiser
Legendary 2500
Legendary 2500
#6 Unread post by jmillheiser »
The steering dampener resists sudden steering movement which can keep a minor case of the shakes from turning into a tank slapper.
I wouldn't worry about getting your chain wet if its properly lubed. the oil should repel water. your fork, shock, and steering dampener are all sealed units and should be waterproof.
I dont have to worry about chain maintainance on my bike, its shaft drive
#7 Unread post by Sev »
Shaft drive would be nice, but I don't mind the extra work to keep the bike I love.
#8 Unread post by BuzZz »
The thin film of oil on the steering damper (not dampener... it damps oscillations, rather than making things wet :wink: ) shaft is a tiny amount of residue that gets past the seals, and is normal. Your damper is not empty of oil, it's inside, where it should be.
VermilionX
#9 Unread post by VermilionX »
BuzZz wrote:The thin film of oil on the steering damper (not dampener... it damps oscillations, rather than making things wet :wink: ) shaft is a tiny amount of residue that gets past the seals, and is normal. Your damper is not empty of oil, it's inside, where it should be.
that makes sense... thanks buzz!
Shiv
#10 Unread post by Shiv »
Potato potahto. It sounds better to say it dampner. (not damp-en-er, just damp-ner).
Dam-per leaves much to be desired and feels like you left something out.
