I'm new to the forum and want to thank everyone for the help.
I'm also new to biking so I want to check with some experienced bikers before I ruin a new rotor.
I changed the brake pads and after I replaced the tire and chain, I spun the tire and the pads are rubbing against the rotor. I pumped the brake several times and I don't think the calipers are returning far enough. Is the rubbing normal on new brake pads or should I not ride until they are completely free when the brakes are not depressed?
The bike is a 1996 DR650 (Suzuki)
Thanks, BP
Should this happen? (brakepads rubbing)
Thanks for the fast reply....
I can spin the tire and it doesn't come to a screeching halt but there is a disturbing rubbing sound that worries me (kind of like metal on metal). When I apply the brake, the tire stops normally.
I just bought the rotor because I ruined the original by forgetting to put a spacer in the tire. I just don't want to make another costly mistake.
Thanks for the help
Thanks for the help
- ZooTech
- Years Riding: 18
That rubbing sound is normal. I have twin rotors up front with dual 6-piston calipers, and mine makes a constant "ssshhhhhhhh" noise while riding. As long as the wheel spins freely by hand I wouldn't worry about it. I would, however, advise you to change your brake fluid at this time, preferably to Valvoline synthetic (AutoZone) if you haven't already. A good flush will get rid of gunk that could clog the return lines causing a legitimate bind in the caliper.
