Car engine oil AS Chain oil
Can i use car engine oil to lubricate a chain on my GSX-R 600 because it is imposibile to find proper chain lubricant in my town.
- Sev
Any motorcycle store should sell at least one brand. Otherwise you can order it online from almost any bike site.
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Where do you live? Hell, I can find chainlube at the autoparts stores here. And the hardware store, now that I think about it...
If you can't find anything in town, use chainsaw oil, sometimes called 'bar oil'.... it will fling less than motor oil..... still gonna be messy as hell though. And I would only use that until the PJ-1 Chainwax I ordered online got there....
No Witnesses....
- Skier
Car oil can be used in auto-oiling systems such as Scottoiler. As for manual application, it'd probably be best to use specifically designed chain lube, which I find hard to believe you can't find. Any motorcycle dealer, or motorcycle parts store, should be able to get you soem. Failing that, you can always find some online.
I live in Serbia and we are very much undeveloped as far as motorcycles are consired. It is very hard to find motorbike equipment here and i cannot buy anything online because credit cards are not accepted from Serbia. I can only try to find a good substitute for equipment i need, and improvise.
Ok, So i can use motor oil but it will probably quickly fly off the chain. It's not so bad.
Thanks for the help guys
- Skier
Ah, gotcha. If there are hardware stores over there similar to Lowe's or Home Depot, DuPont makes a Teflon-based dry lube that I hear works as a decent substitute for chain lube. Might want to keep your eyes open for that.Gixxer wrote:I live in Serbia and we are very much undeveloped as far as motorcycles are consired. It is very hard to find motorbike equipment here and i cannot buy anything online because credit cards are not accepted from Serbia. I can only try to find a good substitute for equipment i need, and improvise.
If all else fails, WD-40. Just remember to apply it frequently, it doesn't stick as well as chain lube and doesn't have other properties of chain lube, but it'll work in a pinch.
- mcmahonm
- Regular
we may need to help
hey we need to take a collection up and ship a couple of cans of chain lube to our frozen friend in Russia.
That sucks, i guess I should stop complaining about the 75KM ride to the nearest dealer.
2006 Suzuki Katana 600
