Hi to All !!!!!!!!!!!!
I have a 1982 Yahama Virago V-Twin 750cc …………………… It had been sitting up for about 12 years, by the time I got it ………….. Looks like the { First of 2 }, Previous Owners, might have been working on it, by the NOTES in the Manual …
I REBUILT the Carbs., myself, as with other Bikes – { mostly 4 – cylinders }, I replaced the INTAKES as well…………. I did NOT get NEW rubber seals for Throttle Shaft with Kit……. Think maybe it Leaks there ???????????? I’ll check Saturday …………. The PROBLEM with Bike { after Carb. Rebuild }, is, it Will RUN on ONE cylinder, or the OTHER, but will NOT RUN SYNCRONIZED { using Sync. TOOL } !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Is this A DEFINATE Carb. Problem { STILL }, or is it POSSIBLE there is a Problem with the something else ??????? I can’t AFFORD to { BUY } REBUILT CARBS., ESPECIALLY, if I do NOT REALLY NEED them ……………………………………….. I need to get the Bike RUNNING, as the GAS PRICES are GOING UP again !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Cold -- you definitely NEED the CHOKE, { on one cylinder }….. After warm up, it will RUN fair on ONE cylinder…….. but NOT on BOTH !!!!!!!!!!! Even with Choke, it Will NOT hardly START, much less RUN !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have NOT checked for Vacuum Leak yet……………………….
HELP
Any ideas will GREATLY APPRECIATED !!!!!!!!!!!!
THANKS !!!!!!!!! D.L.J.
