what is best tire pressure
Good day guys and girls
I got an old kawaski and would like to know what is the best tire pressure for it. I did put new tires on it with new tubes. I have heard that in the back i should have about 42 and the front about 36psi. What do you think???
space_man
space_man
dont dwell on the problem............ think of the solution....
- BDRONAGOLDWING
presssure
The manufacture of the tires has done all of the research for you. The pressure that is stamped on the side is there for a reason. This is the optimal pressure for that tire size and load rating as well as the best handling for that tire. Tire pressures change as much as 5 pounds after the tire gets hot so it is best to check them before you take off. They also vary due to outside temps. So even if it is properly inflated today it may not be tomorrow. I ride a heavy bike so I keep mine at the max pressure all of the time, and can usually tell if they are off even a pound or two. But they will last longer and wear evenly if you watch the presssure reguarly.
Re: presssure
The pressure stamped on the side of the tire is the MAX pressure. Which is not always the optimal pressure.BDRONAGOLDWING wrote:The manufacture of the tires has done all of the research for you. The pressure that is stamped on the side is there for a reason. This is the optimal pressure for that tire size and load rating as well as the best handling for that tire. Tire pressures change as much as 5 pounds after the tire gets hot so it is best to check them before you take off. They also vary due to outside temps. So even if it is properly inflated today it may not be tomorrow. I ride a heavy bike so I keep mine at the max pressure all of the time, and can usually tell if they are off even a pound or two. But they will last longer and wear evenly if you watch the presssure reguarly.
-dennis
2004 Triumph Thruxton 900
2006 Suzuki V-Strom DL650
- TechTMW
- Years Riding: 10
Re: presssure
Correct. Optimal tire pressure is determined by the bike manufacturer and is in the owners manual or shop manual.d2mini wrote: The pressure stamped on the side of the tire is the MAX pressure. Which is not always the optimal pressure.
- gsJack
- Legendary 500
- Years Riding: 30
- My Motorcycle: 02 GS500
The bike mfg has it's recommendation for tire pressure and unless it's been removed it will appear somewhere on the bike. A label on the frame, on the chain guard, under seat, etc. Look for it on your bike.
Tire mfgs have online fitment guides which show their recommended tires for your bike and also the pressure. Also the tire manufacturers have charts showing generally recommended pressures based on tire size and load you are carrying like this one from Metzeler:
http://us.f1f.yahoofs.com/bc/be2f8c8e_m ... CBvfqlOvQL
407,211 miles in 30.1 years for 13,528 miles/year average. Started 7/21/84, updated 8/26/14
