Advice on fast stops in wet weather
ZooTech
Years Riding: 18
Re: Advice on fast stops in wet weather
#11 Unread post by ZooTech »
Heimdall Einherjar wrote:Advice on fast stops in wet weather
Yeah...don't stop fast in wet weather.
basshole
#12 Unread post by basshole »
Personally, it sound like you're unemployed AND STILL OVERPAID!
but since my last employer is a deadbeat scumass who isn't paying me my dues, I'll just have to wait.[/quote]
Beer. Helping ugly people get laid since 1853
2006 Suzuki C50 Silver/Gray
skoebl
#13 Unread post by skoebl »
It rained kind of hard today. And my worn tires really didn't inspire much confidence in my ability to negotiate big city traffic. I really need new tires :cry:
SV650 K6 <---Suuper Awsome bike
[quote="V4underme"]
If I didn't feel like a monkey &*$%ing a football when I sat on a sporty, I'd probably own one.[/quote]
< I Fly >
#14 Unread post by < I Fly > »
Whatever you do, don't slam the rear brake. I've done that and the results can be harrowing.
Kal
Real Name: Jade
#15 Unread post by Kal »
Front brake (50%) then rear brake (50%) followed by feathering the clutch.
A good half my mileage is done in rain, it's no big deal. However I'd follow the advice given by some of the other riders here and take extra care not to put your self in the position of needing a rapid stop.
Once the grease has lifted off of the road and washed away you can ride almost as if you were in the dry with the following thoughts;
Instead of a two second gap in to the vehicle in front give yourself four seconds for the increased braking distance.
Slow it down a little, if you are on a road you'd normally bang out at 60mph try running it at 50mph.
When you see a potential situation ahead of you roll off the throttle and bang it down a gear.
Otherwise keep the acceleration, cornering and deacceleration smooth.
No worries.
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
zarakand
#16 Unread post by zarakand »
Kal wrote:Front brake (50%) then rear brake (50%) followed by feathering the clutch.
No worries.
Excellently put.
Honda Shadow Aero
[url=http://www.totalmotorcycle.com/BBS/viewtopic.php?t=10329/]Chicago Bike Blog[/url]
Mag7C
#17 Unread post by Mag7C »
Yeah don't run fast in the rain in the first place. Because there is a point that you can't slow down fast enough.
In addition to what Kal wrote, I'd like to add that from personal experience it's better to use more of the rear brake and ease up on the front as you come to a stop. With low speeds, if the back slides a bit it's no biggie, if the front slides you'll most likely end up on the ground.
< I Fly >
#18 Unread post by < I Fly > »
Mag7C wrote:Yeah don't run fast in the rain in the first place. Because there is a point that you can't slow down fast enough.
What I've been doing is starting off with the back brake then pulling down on the front when I'm near a stop, to finish off the stop.
Is that not a good idea?
Mag7C
#19 Unread post by Mag7C »
In good conditions it doesn't matter too much. In rain I wouldn't do it unless you need to.
BigChickenStrips
#20 Unread post by BigChickenStrips »
what about a parachute to help slow you like the drag racing cars have. you push a button next to your turn signals and boom, your pushin on the handlbars praying you can stop your body as fast at that piece of cloth stopped your bike. just dont accidentally push the NO2 buttong instead! ouch!
...as ryan brings the thread down another notch...
[b]Alcohol, Tobacco, and Firearms should be a convenience store, not a government agency! [/b]
