Plug Leads
shoey949
Plug Leads
#1 Unread post by shoey949 »
I'm interested in putting on new spark plug leads and plug caps on my '73 honda twin. Is there any way to run new leads or am I screwed b/c they seem to be attached to the coils be some sort of adhesive? What sort of wire and caps do I need, as far as resistance, and what not?
Thanks Nate
1973 Honda Cl 350 (Sold)
1982 Honda 650 Nighthawk
1978 Kawasaki KZ 400 (Sold)
1983 Kawasaki GPZ 550
But someone will say, "You have faith; I have deeds."
Show me your faith without deeds, and I will show you my faith by what I do.
James 2:18
#2 Unread post by BuzZz »
Most coils have the leads attached this way. The core of the lead is screwed onto the output pin of the coil, and then glued in to hold it tight. If you can break the bond and thread the lead off, it should become fairly clear.
shoey949
#3 Unread post by shoey949 »
then do I simply just go to the auto parts store and ask for new leads and caps?
James 2:18
Quick 350
#4 Unread post by Quick 350 »
Any cycle shop will have new boots I use NGK Boots they usually cost me around $1.50 each and a few feet of wire is around another $1.00.
Ask for a good wire and if so go to your local auto parts store and ask for a few feet of 8.8 graphite cored wire. I've found it to improve spark and last a lot longer.
Good Luck!!!
and get out riding!
