Should I stay away from chain drives on a cruiser?
ragin cajun
#1 Unread post by ragin cajun »
As the title asks, from an all around standpoint (maintenance, durability, reliability, safety, etc), should I (as a newbie) stay away from a chain drive cruiser. Saw a Kawasaki Vulcan Drifter today and was stunned by the looks, saw it compared favorably with a Suzuki Volusia 800 that I'm also liking but the chain drive was the big difference.
(Boy, can't wait for next weekend for my MSF course and then to start sitting and looking at bikes).
niterider
#2 Unread post by niterider »
The chain drive does take a bit more maintenance than the shaft or belt.
It also wears a little faster than the shaft or belt, but as for reliability and safety I don't think there is any real difference.
I believe that chain maintenance is nothing that cannot be learned by a newbie.
I prefer the shaft drive, little or no maintenance. Some of this other riders that use the chain can give you better info on that. Have fun riding.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
#3 Unread post by Sev »
Chain drive can deliver the power a lot more abruptly.
jstark47
#4 Unread post by jstark47 »
jmillheiser
#5 Unread post by jmillheiser »
shaft drives can be plenty abrupt as well, if your not smooth on the throttle.
angrypeppers
#6 Unread post by angrypeppers »
Thanks for the link, jstark! I'm glad my post may help out someone else...
:thumbsup:
Chris
Centennial, CO
1979 Suzuki GS1000E
1983 KTM495 - Sold!
1964 Toyota Land Cruiser
1993 Toyota Land Cruiser
1999 F-350 CC 7.3 Turbodiesel
earwig
#7 Unread post by earwig »
In my opinion belt is best. No maintenance at all and you get immediate response... at least if it has a tension wheel or something similar to keep it tight w/ no play. I am not familar with all bikes that use belt as the final drive, but mine requires no maintenance at all and is good for 50,000 miles. The resplacement belt has no set time to replace.
#8 Unread post by Sev »
Final Drive should not be a make or break deal when buying a bike anymore. All three are relatively easy to maintain, and if you get the bike that fits you well you won't mind ANY extra work that may come with the drive for whatever reason. Mine's a chain, and I could care less that I need to oil it, and tighten it once in a while.
You should be more concerned with how good it feels to be sitting on the bike.
BigChickenStrips
#9 Unread post by BigChickenStrips »
real men [and women] use chain drives...
j/k chains are fine if your good on maintenance, dont let final drive be a deal breaker on any bike, all final drives basically do the same thing.
good luck and ride safe
[b]Alcohol, Tobacco, and Firearms should be a convenience store, not a government agency! [/b]
zarakand
#10 Unread post by zarakand »
Chain drives are very easy to maintain, lubing them takes about a minute. As far as tightening that depends on your level of comfort with mechanical tinkering. Though I think its about a $100 to get done at the dealership.
Honda Shadow Aero
[url=http://www.totalmotorcycle.com/BBS/viewtopic.php?t=10329/]Chicago Bike Blog[/url]
