Fork/Motor Oil/ATF
shoey949
Fork/Motor Oil/ATF
#1 Unread post by shoey949 »
The nearest store which sells fork oil is a 45 minute drive away so I wanted to know if I could use ATF or motor oil in my forks. Does motor oil or ATF deteriorate or harm the seals or the forks?Is their any noticable differance in the ride quality?
Thanks,
Nate
1973 Honda Cl 350 (Sold)
1982 Honda 650 Nighthawk
1978 Kawasaki KZ 400 (Sold)
1983 Kawasaki GPZ 550
But someone will say, "You have faith; I have deeds."
Show me your faith without deeds, and I will show you my faith by what I do.
James 2:18
9000white
#2 Unread post by 9000white »
i have always used atf in all my bikes without any problems.
dr bob
#3 Unread post by BuzZz »
Fork oil is fork oil only because it is designed to be a certain viscosity and remain that viscous over as great a temperature range as possible. Well mostly, you still want the lubrication qualities for the sliding parts in the fork, but it's primary job is as a damping medium.
So if your riding an old bike with damper rod forks, the suspension action is well removed from modern stuff anyways, and even a huge change in fork oil wieght will not be as noticable to the ride.
If you have modern cartridge forks with high/low speed comp and reboud adjustment, then it will be much more sensitive to what fluid is in there.
