Wargasm wrote:Still dont' have my 360 running. I've put a lot of time, and money into it now (well, a lot for me).
Got a new starter put on, and a whole new shifter column deal...The guy at the shop said the electric start works fine, but that my battery didn't have enough of a charge to start it. I manage to kickstart it, and drive it around for a bit, before it dies, and cannot be restarted. I don't know much, but it sounds like a stater issue to me...Just a few hours ago though, I fully charged the same, new battery, but it still struggles and will not start...What do I do now? I'm sick of taking this thing into the shop.
I have a CB360 and had a CB350.
FIRST: Check fuses and wire connections. Loose connections are common on these old bikes.
The charging systems are weak. The weakest point is the rectifier. You can replace it with a generic full wave rectifier from radio shack. Anything above a 20 amp rating will do, but I would get a 50 amp rating so it runs cooler . The next bad area is the voltage regulator. The alternator does not have brushes, it has permanent magnets. The regulator simply shorts the system to ground above 15.6 volts. A volt meter is necessary to check it. The regulator is harder to find. A good Googling is in order.
The alternator has 2 charging circuits. 2 coils in the alternator provide ignition power and a slow charge to the battery. The other 4 coils are for lights. If the wiring to your handlebar switch are disconnected or loose connection, yuor alternator will not put out full volts.
Additionally, you do not get much charging below 4k RPM. If you run around at low RPM all the time, the battery goes pretty quickly.
You really need a wiring diagram. I have a 76 diagram. The older ones are a little different as Honda did away with the on/off switch for the lights.
The coils could be bad, you will need a manual to tell you the resistance.
Finally, your magnets could be weak, with replacement the only option. I don'y know how to check them , but I don't believe this is a common problem.
