Scoutmedic -- The trials and journies of a *n00b*
- NorthernPete
- Real Name: Pete
- Years Riding: 11
- Scoutmedic
- Real Name: Barry
- Years Riding: 7
- My Motorcycle: 2003 Honda Gold Wing
I just noticed the flaking yesterday while washing it! First time I've really had it out in the sun. Been nothing but clouds and rain here since I got it!
Yep, I've had to choke it every time I started it cold. And, I have the same squeeky disc brake that everyone talked about as well.
Other than that, I'm LOVING it. I'm glad I chatted with you before making a final decision. Thanks!
Checked my fuel mileage and I'm getting 44 mpg right now. I'm hoping to watch that figure gradually rise.
- Scoutmedic
- Real Name: Barry
- Years Riding: 7
I did the oil change myself and is very easy except for one thing as stated in the owners manual pg.7-29, there's a major typo. It indicates to tighten the oil filter 2 turns past contact with the base. This is very wrong!
I'm not a very good motorcycle mechanic and have no prior experience working on cycle engines,but I was following directions and did what the manual stated. Disaster!
I could barely get the oil filter to tighten 1 1/2 turns. Now thinking,common sense would have told me this is wrong since I have changed oil filers on my truck and riding mower and only have tightened them with about 1/8 turn past contact.
But I thought it was different for a motorcycle. Soooo.... I followed directions and when I was finished I started the bike and let it idle for about 5 mins. and checked for any oil leaks and it was ok. Then I decided to take it for a mile or so down the road and come back home and recheck the oil level and inspect for leaks. I got less than a mile when the oil and coolant lights began flashing. Thinking it was a malfunction in the electrical system I pulled off the road and looked down on the right side the bike was spewing oil from the filter
I shut it off and sat there dumbfounded. I checked the oil leved and I lost 75% of the oil. So I turned around and slowly rode back home around 30mph with the oil spewing out and it was smoking due to the oil on the exhaust pipes. I made it home ok.
The next day I went to my dealer to buy more oil and a filter and explained what happened and showed them the owners manual about the directions for the filter. They couldn't believe what they read too. The mechanics and staff were passing the manual around and everybody read it. They told me it's a typo and the mechanics said I overtightended it. Duh! So I'm going to contact suzuki about the typo. Live and learn the hard way I suppose. Also the bike didn't suffer any engine damage or the transmission. What a mess it made. There was oil under the rear fender well and the wind had sprayed oil from the brake pedal all the way back to the license plate. It took 2 handwashings with Dawn dish soap to remove all the oil. After that I gave the entire bike a good waxing.
Not sure if there's any more typos in the manual but If I have any doubts before I attempt any maintenance I'll contact my dealer.
- Scoutmedic
- Real Name: Barry
- Years Riding: 7
Thanks for warning. I remember reading that "two turns" and thinking it was too much. Sounds like that was an aweful mess. I'm going to have the dealership do the first service since they change all the fluids. After that, I'll be doing them myself. A motorcycle mechanic recommended Amsoil. It's a bit more expensive but, he swears by it.
A co-worker said we might be able to solve the cold start problems with hotter plugs. I may try this after the break in period as well. I'll let ya know how it goes or if I hear differently about it. Figured I'd just keep the stock plugs as my spares.
I still need to get more photos of the bike in the sunshine and with me in my gear. Maybe this week I'll be able to talk my wife into it.
- Scoutmedic
- Real Name: Barry
- Years Riding: 7
- NorthernPete
- Real Name: Pete
- Years Riding: 11
- Scoutmedic
- Real Name: Barry
- Years Riding: 7
