If you bypass the switch, make sure it won't come undone while riding. It would suck to have the engine quit at a bad time.
The switch is normally closed when the kick stand is up. So you can remove the wires from the swtich and solder them together to bypass it. Make sure you leave some excess on the switch end so you can later solder in the switch when you replace the kick stand.
But my recommendation would be to just buy a new kickstand and install it, then everything will work normally again with much less work.
kickstand kill switch
- Legendary 500
- Real Name: Daryl
- My Motorcycle: 2004 Ducati 620ie
