really stiff rear brake
#11 Unread post by Sev »
Dirtytoes wrote:
Sev wrote: I can't help but notice that most of the time you do your own maintenance something ends up wrong. Maybe you should be going to a shop?
LOL :laughing:
did u also notice that i always end up solving the problem?
NO, we end up solving the problem for you after hours of trying to beat both common sense into your head, and answers out of your head. I'm still not sure "which two bolts" you took out.
The R6 does not have the same caliper.
now here is the thing...i took the bike for a spin today...maybe 5 miles...i rarely used the back brake....when i got back...the rear rotor was HOT...so i'm thinking maybe the pads r somehow already against the rotor...and that would mean that i would need new pads every week.
Yeah, do that... you're now 3 times as likely to lock the back wheel for no reason. The head coming off of there will warp the disc, and it's likely that it'll jam, again locking the back wheel. You're going to need to buy a new disc ($150) every time you buy new pads every week.
Seriously, how stupid can you be?
AGAIN, I think either the piston went in wrong when you shoved it back and has jammed against the brake pads. OR one of those "bolts" you took out was a caliper sliding pin, and it's in place incorrectly, causing the caliper to lock in place... but I'm 90% sure your rear caliper isn't a floating type.
Dirtytoes
#12 Unread post by Dirtytoes »
Sev wrote:
LOL :laughing:
honetly, if u wanna talk sh*t. i DON'T need ur help.
i'll double check on the sliding pin later today.
ps. the R6 does have the same rear calkper...checked last night.
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
[img]http://www.MegaShare.com/images/images/553227170/humor00180.gif[/img]
Bikes:
2005 Ninja 500 (sold)
2001 CBR 600 F4i (current stunt/commuter)
Dirtytoes
#13 Unread post by Dirtytoes »
i took off #13 and #16
Bikes:
#14 Unread post by Sev »
Don't care, you're on your own.
You know better then I do.
#15 Unread post by BuzZz »
Get used to it Skooter. If you wanna work as a bike mechanic, your days will be filled with similar 'challenges'.
Oh yes, there is a reason I don't work on the general public's stuff. :wink:
:laughing:
#16 Unread post by Sev »
BuzZz wrote:Get used to it Skooter. If you wanna work as a bike mechanic, your days will be filled with similar 'challenges'.
:laughing:
Shrug, work is pretty easy that way.
The work order shows up and it says, "do X." I do X, and it either solves the problem or it doesn't. If it doesn't solve the problem the customer gets angry, takes it out on the service desk and they make up a new work order that says, "do Y." Things repeat until the problem is solved. I never have to deal with the customers :D!!!
I do this trouble shooting thing on here because it's just a chance to experience new problems and test my trouble shooting skills. If someone were to read through the forums they would realize that there are hundreds of problems with answers on here. Remember the symptoms and remember the solution.
However sometimes it's not the bike that's the problem, it's the owner.
#17 Unread post by BuzZz »
Sounds like a sweet gig.
You guys hiring? :laughing:
#18 Unread post by Sev »
Sadly, yes.
