Weak front brake
- Skier
Shorts, try spraying some brake cleaner on a rag or paper towel and wiping down your rotors. That will clean a lot of gunk off them.
I dunno what Japan has for brake cleaner, though.... it's probably smaller and more efficient than what we get here in the States.
- Sev
If you're feeling really ambitious you can pull the brakes off, pull out the pads spray them down with brake cleaner, rub them gently with a little sandpaper, brake clean them again and reinstall them.
I'm going to be doing that this weekend probably
- Nibblet99
Also there is the age old, "lazy bugger" trick: Wrap a bungee cable as tightly as possible holding the brake applied and leave it over night. Any air bubbles should work their way upwards and out.
If its much better, its a problem with the fluid (Bad fluid or and air leak somewhere). If its hardly noticable difference, its probably crap on your pads / glazed disks.
Steel brakelines will also add some more responsiveness too
