Lesson learned brings about new question
- onin24eagle
- Regular
- Nibblet99
If you took the training, you'd most likely know, brake before turning (not during), slow in, and apply some power as you see your exit.
Braking whilst in the corner will actually INCREASE your turning radius and make it harder to turn.
If you misjudge it, and go in a bit hot, you should be using the rear brake to strim off speed.
The MSF-BRC isn't the "be all" and "end all" of tests, you seem to think it is fresco. It sets the foundation skills for you to then go and learn by yourself on the roads. Its pretty much what you're trying to do now, but with accurate information and guidance.
I hope this helps, and that you decide to take a more sensible (in my opinion anyway) approach to learning.
Plus for the record, what seems like the right way to do something, usually isn't with motorcycles, and habits are a "dog" to unlearn
- storysunfolding
- Years Riding: 22
As opposed to fuel injection? That doesn't make sense to me as the fuel source doesn't determine your engine braking speed.erbgottie wrote:well, having a carb,...
Anyway- for any sort of turn, it's best to add a bit of power as you go through it. The goal is to set a good entry speed that allows you to maintain or increase speed throughout the turn. That will obviously vary depending on the situation.
When you are in a turn and you're going too hot the best option is to push more and lean the bike over further to complete the turn. As long as you aren't scraping hard parts, you have lean left. Granted you're going to want to stop after the turn, take a deep breath and wipe off the seat. Braking in a turn, however, can be disastrous.
So slow down well before the turn, look as far through the turn as you can looking for your exit point, press to lean and roll on the throttle as soon as you see the exit point.
And sign up for an instructional class before you hurt yourself in one of these falls. Motorcycling is very counterintuitive and learning by yourself is proven to be the worst way to learn.
Nibblet99 wrote: The MSF-BRC isn't the "be all" and "end all" of tests, you seem to think it is fresco. It sets the foundation skills for you to then go and learn by yourself on the roads. Its pretty much what you're trying to do now, but with accurate information and guidance.
excellent response nibblet, really appreciated this one, as I did yours storysunfolding
so basically, slow, look, brake more if needed, turn+ apply some throttle if needed - no braking in the turn
- jonnythan
No braking in the turn including engine braking. The roll refers to rolling on the throttle to maintain speed or accelerate through the turn. This allows you to maximize traction.fresco wrote:Nibblet99 wrote: The MSF-BRC isn't the "be all" and "end all" of tests, you seem to think it is fresco. It sets the foundation skills for you to then go and learn by yourself on the roads. Its pretty much what you're trying to do now, but with accurate information and guidance.
- Nibblet99
You're most welcomefresco wrote:excellent response nibblet, really appreciated this one, as I did yours storysunfolding
- Dichotomous
- Legendary 300
yes that works wonders when you know whats going to happen all the way through the turn. but cars ahead of you brake, or in general things happen that make it so this is often impossible. I brake through almost every curve, trail braking I belive they call it, and yeah its a balancing act. I'm not talking grip the lever like a rattlesnake braking, but letting off the throttle or light brakes. to say never do this, in the real world, is laughablejonnythan wrote:No braking in the turn including engine braking. The roll refers to rolling on the throttle to maintain speed or accelerate through the turn. This allows you to maximize traction.fresco wrote:Nibblet99 wrote: The MSF-BRC isn't the "be all" and "end all" of tests, you seem to think it is fresco. It sets the foundation skills for you to then go and learn by yourself on the roads. Its pretty much what you're trying to do now, but with accurate information and guidance.
- Brackstone
- Legendary 1500
- Real Name: David
- Years Riding: 3
- My Motorcycle: 2010/Ducati/Monster 1100
I just noticed that this is the same guy from another thread
viewtopic.php?t=25040
I told you to take MSF Courses before too
Aprilia Shiver 750 (sold)
Might I also recommend the Keith Code Superbike School. As a former instructor, we taught to get all the braking done while straight up and down, then off the brakes and turn the bike.
Now taken a step further, as a racer, I've also braked all the way to the apex and further if I screwed the approach up or pasing someone while leaned over. That takes a very careful touch in a very controlled environment. The street isn't the place for it.
