jonnythan wrote:storysunfolding wrote:NNYrider wrote: Inflating to max value will ... dramatically reduced traction.
By altering the laws of physics where traction is solely dependent on weight and the coefficient of friction.
But second to all the rest of it. Max pressure isn't at all what you want to ride. Don't thank us, thank your not sore "O Ring".
Uh, no.
The higher the air pressure in the tire, the lower your traction. This is because higher pressure = smaller contact patch.
A tire at 20 psi has more traction than the same tire at 40 psi because the contact patch is larger.
This doesn't mean that lowering the pressure beyond recommended is a good idea - it leads to more and uneven tire wear, more rolling friction, etc.
Hi jonnythan
If I remember my college physics, storyunfolding is correct. Friction (traction) is not dependent on the size of the contact patch between tyre and road. It is dependent only on the weight of the bike (the Normal Force between the two surfaces) and the specific value of the coefficient of friction between the tyre compound and the road.
The physics is very complex I seem to remember, but in simple terms it goes like this: when you increase the area of contact between two objects, you lower the pressure exerted by one on the other (that is, if you assume the force between them - the weight of the bike in this instance - remains constant). This reduction in pressure exactly compensates for the increasing area on which frictional forces can work. In other words, increasing area and reducing pressure cancel each other out.
So, as counterintuitive as it sounds, the size of the contact patch does not affect the amount of frictional force generated between a tyre and the road. That is true of any two surfaces.
I've never thought about this in terms of tyre traction before, so I'm puzzled. If the size of the contact patch is immaterial, why does tyre pressure make such a difference? (Perhaps it isn't immaterial. Are there other forces operating here that are being overlooked?) Anyone know the answer to this?
