You are actually agreeing with me on this one. I said that the less strength you have, the more technique you need. The more strength you have, the less technique you can get away with.storysunfolding wrote:Im going to have to disagree on the strength issue. I teach a maintenance course at three sites. Never had anyone have an issue getting a bike on a rear stand. It's all about technique. It's the same way the 80 year old grandmother on YouTube can lift a goldwing on it's side. Once you figure out the technique, you are golden
huhHyper wrote:Also BMW is the only one that makes a real centerstand.
He's referring to the fact that most other centerstands aren't at the weight's center and require a bit of weight on say the front of the bike to get it off of the rear tire.Johnj wrote:huhHyper wrote:Also BMW is the only one that makes a real centerstand.
Exactly. It is almost like a perfectly balanced seesaw. You can poke it with one finger to either make the rear go down or the front go down. You can remove either wheel without doing anything but putting it up on the centerstand.Wrider wrote:He's referring to the fact that most other centerstands aren't at the weight's center and require a bit of weight on say the front of the bike to get it off of the rear tire.Johnj wrote:huhHyper wrote:Also BMW is the only one that makes a real centerstand.
All beemers have it just SLIGHTLY off of the weight's center, it's literally the difference of a riding jacket's weight on a K1200LT to get the bike from being on the rear tire to being on the front tire.
I'm honored that you think I can teach a student the perfect technique from the very beginning .HYPERR wrote:You are actually agreeing with me on this one.
The Wing is not actually on its side, it is at a 45 degree angle, quite a difference.
The great thing about a Goldwing is that it will sit at that angle without doing any damage to the bike. Besides, at 800lbs + that's still quite a lift. You can actually lay the new wings over like that and do a rear tire change...HYPERR wrote:The Wing is not actually on its side, it is at a 45 degree angle, quite a difference.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
