2017 Harley-Davidson Tri Glide Ultra - Coolness Factor = 47.4%
Your Coolness Factor of the 2017 Harley-Davidson Tri Glide Ultra is:
View results
Re: This Week: 2017 Harley-Davidson Tri Glide Ultra - VOTE NOW
#11 Unread post by totalmotorcycle »
It was hard to choose between Cool and Uncool. So I went Uncool.
For me, I donno, they are so unique that I think either you like them or you don't. Maybe it comes from the early 80's "home made" garage type trikes that were more death traps than actually bikes. They were just plain horrific in everyway. So today's trikes are light-years more advanced, but in my mind, are kinda uncool still versus a side-car hack...
With that, comes the price... OMG, "How much!?!?" Ya, and that's me laughing while I run away from the dealership.
all that aside, if you NEED TO HAVE a trike, say you are older or disabled, then hey, more power to you for owning one. If someone sees you can't ride a bike but ride a trike, that's KUDO'S to you my friend and I want to be you then if I was in your shoes. In which case, the Trike goes from Uncool to Awesome.
#12 Unread post by totalmotorcycle »
Featured: March 10th, 2017 - March 17th, 2017
Most popular vote category: TIE Cool/Uncool
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=54258
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... -Ultra.htm
Awesome (3 points) 2
Cool (2 points) 7
Uncool (1 point) 7
Fail (0 point) 3
Total votes: 19
= a Coolwall Factor of 47.4%
Total Motorcycle's Take-a-way:
Better shaken than stirred. 2017 Harley-Davidson Tri Glide Ultra seems to have left a bitter after taste, not because it's a Harley-Davidson, but because a three wheeler just isn't as "accepted" as a two wheeler. It is like showing up in your cool car on bike night, it just doesn't fit in that well with that crowd.
Other negative points was the huge cost of it... you could buy 2 or 3 Harley-Davidson's for the same price. Then there is the questionable handling... It's not Harley-Davidson's fault (maybe the price) per-se, it's just not the right crowd.
Get excited as the next TMW Cool Wall bike for 2017 is now up for voting and discussion, have fun!
niloypal
Real Name: niloy pal
My Motorcycle: 2022
Re: 2017 Harley-Davidson Tri Glide Ultra - Coolness Factor = 47.4%
#13 Unread post by niloypal »
You have to love bike ride explore every where but you face your phone speaker doesn't work properly then you just try To fix my speakers , start with the diagnosis. Ensure that it's getting power and its cables are securely connected. The speaker should be tested with other devices to eliminate issues with the audio source. If there's a lack of sound, garbled sound, or static, examine the speaker cone for physical damage like tears or dents. Open the speaker cabinet (if safe and unplugged) and check internal parts for loose wires, burnt components, or blown fuses. Check for continuity using a multimeter and verify that the speaker drivers and crossover parts are functioning properly. Clean out any dust or debris because it can lead to overheating or distortion. Re-solder any faulty connections and replace defective components such as damaged cones, fuses, or drivers. For smart or Bluetooth speakers, reset, update firmware, and reconnect the device. After repair, reassemble the speaker with caution, making sure all parts are properly aligned and in place. Always test the speaker after repairs before complete reassembly. If you're not sure or the issue continues, it's best to have a professional technician handle it to prevent further damage.The official web page https://fixmyspeaker.org/
