cb360 electrical troubles
cb360
#11 Unread post by cb360 »
Thanks for the tip - how much do you put in? My mechanic (I do all my own wrenching on the cb360, but the magna is a bit more complicated) said the carbs didn't really need a full cleaning but he recommended I throw a couple tanks of lower octane fuel that burns hotter in there to help clean things out a little bit.
1974 Honda CB360
1985 Honda Magna VF700c
9000white
#12 Unread post by 9000white »
always run lower octane fuel.
i put a can of carb cleaner in mine twice a year.it keeps the goop out of the idle jet passages.they are tiny.higher octane fuel would only be needed if detonation was a problem.it is rare on a liquid cooled bike if everything is in good shape.use about 1/4 of a can of carb cleaner every 3 months.
dr bob
92civeg
#13 Unread post by 92civeg »
ok well i figured out how to jump the solenoid and it will crank all day but wont start...got spark and fuel...maybe ill try some tuneup parts....plugs and points..anyother recommendations?
thanks
