MotoCrash
#21 Unread post by Sev »
It works sort of like those air tubes on a swinging screen door, but in both directions. It helps prevent a sudden swing to the left or right. But hopefully won't change normal handling tooo much.
scan
Re: fdfd
#22 Unread post by scan »
scanevalexec wrote:
Dirtytoes wrote:
Chip Beazley wrote:RE: The speed wobble movie...
If you are going to make a practice of riding really fast on a crotch rocket, a good steering damper is well worth the $450 - $500 they cost.
i myself am stil a little confused.....what exactly does the steering damper do?
Easy. The damper is connected to the bars and runs to the frame. It is a small shock absorber. It stops the handlebars from being free to just swing back and forth (a tank slapper). The lighter and sportier the bike the more likely a steering might help.
Like this -
When the front end gets light it makes it harder for the bars to swing loose.
* 2003 Kawasaki ZRX1200R *
Dirtytoes
Re: fdfd
#23 Unread post by Dirtytoes »
Like this -
oh i see.......now are those for really sporty bikes? or would you put on on for example a gixxed 750?
scan
#24 Unread post by scan »
Any short angled bike will have a likely application. Gixxer, Ninja, CBR - punch "steering stabilizer motorcycle" and you'll find a bunch of applications. Not very likely you'd see them for cruisers though.
