thanks scan! i appreciate it.scanevalexec wrote:http://www.cyclegear.com/lpgm.cfm?L1=52 ... UC_31-7121
This isn't the same thing, but I couldn't find the one I bought. When I go to the store I'll see if I can find it again. I think the one a bough is for ATVs really, but it worked well on my chain.
I think the one I just linked would require more work, but I notice you can replace the brushes on the one I linked. Mine you have to clear the brushes and throw the whole thing out. The thing I liked better about mine was that you could hook it on and spin the tire over and over and keep adding oil until the chain looked good. The tied down held it so it could keep going (in only one direction). But the hand held thing looks pretty good. When I find out what the other thing is called I'll let you know.VermilionX wrote:thanks scan! i appreciate it.
do you think that will work quite as well the one you're using?
This is what I believed for a long time but there are enough people out there claiming that it works that I am going to give it a try on my current chain. I'm about 5-6000km in and the bike is remarkably clean. I really WANT this to work out but I will keep all posted on my results. Like I said earlier, my last chain went 36000km and was not in bad shape when I replaced it so I have set the bar pretty high. We shall see....icariz83 wrote:For those using WD-40:
WD-40 penetrates past the o-rings and washing the grease out of the links!
thanks for keeping us posted on your WD-40 challenge.High_Side wrote: This is what I believed for a long time but there are enough people out there claiming that it works that I am going to give it a try on my current chain. I'm about 5-6000km in and the bike is remarkably clean. I really WANT this to work out but I will keep all posted on my results. Like I said earlier, my last chain went 36000km and was not in bad shape when I replaced it so I have set the bar pretty high. We shall see....
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
