storysunfolding wrote: and a gas gas
What exactly is it that you think you're doing here?Grey Thumper wrote:In a sweeping turn, I sometimes (though preferably rarely) use it to stabilize the chassis.
Like I said, it's something I prefer to do rarely (if at all) because it means I need to correct a mistake, and went into a turn with a bit too much speed (or the turn is slightly downhill). Obviously, rolling off the throttle and using the front brake is an absolute no no in this case. But I find that keeping the throttle steady and just applying a tiny amount of rear brake can scrub off just enough speed and make the bike feel more stable. Note: it's basically - uh - a dab of rear brake, and doesn't involve keeping the rear brake on; that leads to its own set of problems.storysunfolding wrote:What exactly is it that you think you're doing here?Grey Thumper wrote:In a sweeping turn, I sometimes (though preferably rarely) use it to stabilize the chassis.
People just use the front break? I hear it makes you fly over your handle bars so I only use the rear.Wrider wrote:They were right with the rear brake through slow corners. But you need to use the front brakes more than the rear when stopping from high speeds. The front brake provides 70% of the stopping force under normal conditions. I'm not recommending just using the front brake, but I know a lot of people who do.
You know this is an interesting statement, especially given your first one, and I'm not 100% sure how to address it without sounding like a complete jerk. One thing to note is that using the front brake or rolling off the throttle IS an option, even for street riding. It's also not that advanced a technique and something I'm sure many reading this have done once or twice. Getting some intruction on how to do this will give you a much better, precise and refined tool for what you are talking about. Obviously severe applications of the front brake or a big roll off create a different scenario hence why we tell beginners not to ever do these.Grey Thumper wrote: Like I said, it's something I prefer to do rarely (if at all) because it means I need to correct a mistake, and went into a turn with a bit too much speed (or the turn is slightly downhill). Obviously, rolling off the throttle and using the front brake is an absolute no no in this case.
shane-o wrote: Front
Rear
engine
Tadahhh!!!
I spent a lot of time trail braking hard into corners using all three brakes a few years ago just for the fun of it. Ienatsch is right on in the quote above, your rear brake can be your best friend in corners.gsJack wrote:Learn to use all three of your brakes all the time; front, rear, and engine.......................
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
