Do you mean fresh spring air to replace the stale fall air in the tire?
lol...yes. In my state when you get your MC or car inspected, they analyze the air in your tires and if it's stale, you dont get your sticker and what's more... if you don't replace the stale air with fresh air air within 30 days you are hit with a steep fine! Furtermore, you may not release the stale air from your tires into the atmosphere (Texas goes to great lengths to ensure optimal air quality for it's citizens). It must be recovered and taken to a proper facility for reprocessing.
(I'm fairly certain Ofblong will be along shortly to dispute this.)
sorry cant dispute something I know nothing about.
You knew I was spoofin' about the stale air thing, right?
I didnt believe it but I dont know the laws in certain states. I mean some people come up with the STUPIDEST ideas in the world (like changing stale air) and some how it becomes a law.
I would say the front brake should be feathered (covered) at best useing the back tourqe from the rear wheel drag alittle back brake as needed to keep the front wheel in line (not skid) slow down to apoint where you are stearing not counter stearing BUT a controlled slide is better than a skid
allday
SEMPER FI
05 RC-51
06 800 bulevard
05 XR- fiddy
WISH I HAD A 1098
Lisa wrote: I had one old biker tell me if I needed to make an emergancy stop that i should lock up the back put it in a slide and jump off the bike. WTF? doesn't that leave me bikeless and out in the middle of traffic? I think most problems with the front brake are people just don't know how to use them and do a full on method of braking
Yes this should leave you bike less. That old biker who told you this, comes from old school, back in the day old bikes did not have front brakes. The only way to get away from your bike was to kick off.
This idea I believe came from an old movie.
Also some bikes (especially a heavy cruiser) with single disc front brake,will shift the bike, in other words it may pull hard right, scaring the "pee" out of someone.
I have a single disk front brake and I never have that problem with pulling Left (disk is on left side of front tire). Then again I have only had to use emergency breaking once and it was 2 weeks after I first got my bike.
It's usually only a factor having one disc up front when your forks/axle aren't quite properly aligned. Same thing with my Volusia though. One front disc (right side) and it never pulled the wheel to the side during stops.
