? re kickstart on elect. start
Gnarlyroad
#1 Unread post by Gnarlyroad »
I have a 83 650 nighthawk and although I keep thinking I have my electrical problems solved things seem to keep happening that make me wish I had a kickstart rather than push button start. My ? is this. Can I convert or add a kickstart without radically changing any thing mechanical or electric to do so. Or am I just pissing into the wind.
9000white
#2 Unread post by 9000white »
you are most certainly pissing into the wind.
dr bob
kar_the_terrible
#3 Unread post by kar_the_terrible »
doubt that would be possible, because you would have to make a hole in the engine casing and build a gear train to turn the engine.
Not recommended. invest in a good starter solenoid, cabling, and possibly a wire harness.
'78 Yamaha XS400
'86 Yamaha Radian
