ignition timing 2000 tw200
buud
#1 Unread post by buud »
does the plug fire every time the piston reaches the top, both compression and exhaust? i'm having a time trying to install the cylinder and cam sprocket chain and all without the chain dropping off the lower sprocket. i think i got it wrong the first time resulting in a bent intake valve. new valves on the way now.
#2 Unread post by BuzZz »
I'm not sure. What does the service manual say?
ElectroKen
#3 Unread post by ElectroKen »
The TW200 has a waste-spark ignition system and fires the plug on every crankshaft rotation. For what it's worth I don't believe that's mentioned anywhere in the factory service manual.
1972 Honda CL350K4
2003 Kawasaki Concours
2005 Yamaha TW200
