Headlight
bush0117
Headlight
#1 Unread post by bush0117 »
Hope someone can help me. I got a 1981 650 Suzuki with a windjammer Iv on it. It has a chrome plastic ring around the light and I can't seem to firgure out how to change the light. Any help would be nice.
Thanks,
Jason
Gadjet
Real Name: Owen Clark
Years Riding: 19
#2 Unread post by Gadjet »
it probably takes a standard H3/H4 bulb. You should be able to disconnect the plug on the back of the headlight and remove the rubber cover over the bulb socket. There should be a spring clip holding the bulb in - pop this clip loose (will swing to one side), remove the old bulb and put in a new one.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
